Old 08-20-2007, 09:13 AM   #1
Rodger
That works for an inner boot but what about an outer? I have a broken outer and also havent been able to find a Bentleys, do you just unbolt the inner and then remove the axle nut for the outer? It might actually be easier as then you shouldnt have to touch the exhaust, any suggestions??
Come to think of it, that's the procedure I used when I did mine. I did mix it up a bit, though, because I had major difficulties getting the outer joint out of the hub. I'm 99% certain you could still do an outer the same way, you'd just have to remove the inner boot first (replace them all while you're at it).
http://i19.photobucket.com/albums/b1...dingAvatar.jpg
Sold September 4th, 2007.
Rodger is offline   Reply With Quote
