Old 12-23-2004, 08:54 PM   #2
Tool Pants
http://www.renntech.org/forums/index.php?showtopic=178&st=0&#entry534
If you mean the clear headlights, then you want to remove the internal plastic amber lense. It is too big to pull it out of the hole for the bulb unless you do something to the internal lense to make it small enough to pull out of the hole. Meaning you have to destroy the amber lense so you can yank it out
This is the size of the lense. So you will not be confused. The 3 sided clear lense in my pic is clear because it is from an externally amber headlight I took apart. The lense in the clear halogen or litronic headlights is amber.
Tool Pants is offline   Reply With Quote
