Thread: Losing weight
Old 08-19-2007, 09:40 AM   #11
blinkwatt
Send a message via AIM to blinkwatt
The first thing I would do is remove your battery and replace it with a Braille or other lightweight battery. They weigh 10-15 lbs depending on which one you get, that can save you 30 lbs or so.
How much are the Braille batteries? Do I need a custom mounting kit?
After that, weight savings gets quite expensive. Going to a single set of high-flow cats and headers can save another 25 lbs, and give you a few extra hp, but doing so can result in CEL error codes if not done correctly (I know this from experience).
Changing the cats is a no-go here in California on the non e-gas,the e-gas folks can get away with it.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
