Old 08-13-2007, 07:13 PM   #1
P-DUB
Well.....It's fuel injected, and that's a huge nono! You probably loaded it up with fuel (gray smoke) and your car is trying to get over it. You many have fouled the plugs depending on how much gas we are talking about here. You might want to see if it will crank over and fire without any throttle, once running, let it warm up with no throttle, and then go for a short drive, but stay close to home ansee if it clears itself out. Let us know what you find out, but I bet that's what happened, and it should be able to recover, and the worse thing you may have to do is change the plugs. Anybody else with me on this, or am I all wet?
First I had none, now I have two. What was I thinking?
P-DUB is offline   Reply With Quote
