Old 08-11-2007, 07:16 PM   #1
clb0099
yes i don't see anything at all.....
Now here is what i got from alldata.com
Fault Code 25
No terminal 86 S recognized.
Check the fuse F 5/1.
Pull off Plug I at the alarm control unit.
Voltmeter at Plug I alarm control unit pin 16 and ground. Insert the ignition key into the ignition lock. Display: Battery voltage
Pull off the plug on the ignition lock.
Ohmmeter at ignition lock connector pin 86 S and Plug I, alarm control unit pin 16. Display: < 5 Ohms
If no fault is detected, replace the electrical contact part of the ignition lock.
Fault Code 33
Passenger compartment monitoring sensor faulty.
Replace passenger compartment monitoring sensor.
Test Point 41
Fault Code 42
Wrong key or wrong transponder pill.
Check transponder for presence in the key.
Wrong transponder - not adapted to the vehicle - teach the transponder.
Test Point 9
TEST POINT 9
motor, Footwell / Defrost Valve Signal Implausible
DTC 28
Fault Effect: Valve cannot be adjusted
Diagnosis Conditions
No control module fault stored.
No fault on the supply voltage (5 Volts ).
Signal Implausible
Check footwell / defrost valve for smooth operation.
Pull off connectors A, B, C and D on the heating/air conditioning control.
Pull off connector on the footwell / defrost valve drive motor.
Check drive motor circuits for continuity.
Connect ohmmeter to connector C-8 and drive motor connector pin 1.
Display: < 5 ohms
Connect ohmmeter to connector B-10 and drive motor connector pin 2.
Display: < 5 ohms
Connect ohmmeter to connector A-12 and drive motor connector pin 3.
Display: < 5 ohms
Connect ohmmeter to connector D-11 and drive motor connector pin 4.
Display: < 5 ohms
Connect ohmmeter to connector D-3 and drive motor connector pin 5.
Display: < 5 ohms
Check wire from connector C-8 to drive motor pin 1 for short to plus and short to ground.
Check wire from connector B-10 to drive motor pin 2 for short to B+ and short to ground.
Check wire from connector A-12 to drive motor pin 3 for short to B+.
Check wire from connector D-11 to drive motor pin 4 for short to B+ and short to ground.
Check wire from connector D-3 to drive motor pin 5 for short to plus and short to ground.
My only questions are where is the "Passenger compartment monitoring sensor faulty"... replace what sensor? Pull off connector on the footwell / defrost valve drive motor where is this? the last question is where is there a Check the fuse F 5/1 in the car?
clb0099 is offline   Reply With Quote
