Old 08-03-2007, 08:48 PM   #1
nola mike
your radio should have an antenna out lead (or another 12v switched). connect this to the white wire in the porsche harness--it's in the black connector i believe. there is also a white speaker wire, which should be obvious as it's with all the other speaker wires and is paired with a white/black wire. hth, though i still haven't received a response to my other questions--anyone know the answers?
Originally Posted by jvmoney
Sorry to hijack your post slightly, but I have an 02 Boxster S and had the same reception problem you mentioned after replacing it with my aftermarket JVC KD-AVX2 unit. What did you do to fix the reception issue?
nola mike is offline   Reply With Quote
