Old 08-03-2007, 11:44 AM   #4
Charlot
Thanks for the advice
Update.
The check engine light wasn't working so I changed it because the codes wouldn't appeared without it.
Code P1691 : Check Engine Malfunction Indication Light (MIL) - Open Circuit
---> We just changed the light and it's ok now.
Code pending P0102 : Mass Air Flow Sensor - Below Lower Limit
---> The MAF sensor has been changed... could it be something related to the MAF that brings this code ? What does it mean : the sensor is not working properly or the sensor detects something is wrong ?
I erased the codes to see if they would come back when I start the engine. Nothing happened and the it ran really fine ! Seems like an intermittent problem...
Any clues on what the problem is ? Oil separater ?
Charlot is offline   Reply With Quote
