Old 08-02-2007, 11:02 AM   #3
skip_168
Originally Posted by bmwm750
Exactly. It is solid (alu with steel friction surface), which is bolted to the engine, which all spins as one unit..... so I still don't see why it would chatter, even though I've heard from several that this just comes with the territory....
Patrick
if everything is tight on the flywheel, the noise most likly is coming from the clutch disk or pressure plate....
skip_168 is offline   Reply With Quote
