					Originally Posted by Schnell!
				 Maybe it chaters because of the lack of springs, as in the dual mass flywheel? I would suspect the dual mass is quite a bit better a dampening any chatter, whereas the solid (it is solid, right?) light flywheel has no chatter dampening. |
The alu. flywheel is a solid mass,(well aluminum with a steel plate where the clutch contacts it..), If that was going to make noise, sumtin' might be loose...
