Old 08-01-2007, 09:16 PM   #1
zackwatt
>Step Three: Unbolt and Remove Seatbelt Mechanism
Slide the Orange switch outward to Unlock the wire harness. Then, gently pull off the harness
Next, Unbolt the Mechanism
After removal of the bolt the Mechanism is still held on my a 3/4 inch "rod"
To remove, pull away and outward from the roll bar. There is JUST enough room to do this.
Thats It!!!
These are the parts left over required to install new seat belts
Overall this was a really, really, easy job. I hope I have motivated some of you to replace your seat belts with some new fancy ones. Good Luck
http://img412.imageshack.us/img412/9591/65zxg8pcz4.jpg
2002 Boxster S
Guards Red/Black
Hacks: De-Snorkeled, Clutch Swich, Debadged, Red Seatbelts, Painted Bumperettes,
986S Badge, EVO Intake, SuperSprint Exhaust, Fabspeed Cat Bypass
My Car: http://s220.photobucket.com/albums/dd74/zackwatt/
zackwatt is offline   Reply With Quote
