Autozone Duralast 48-DL group size 48 was $85 today. Exact fit replacement with the vent tube and everything.
Autozone also had one of those memory things to keep all your settings while the battery is disconnected for $5. You just attach a 9v battery to it and plug the other end into your cigarette lighter. That way you don't have to reprogram the radio, clock and whatever else you may have. I don't know if these things prevent the radio from needing the radio code when you're done (I don't have the stock radio) but I bet it works for that as well.
