Old 07-28-2007, 12:21 PM   #1
Adam
Originally Posted by koboxster
Unfortunately I have no warranty! Anyone have an idea what a factory reman from porsche may cost? I have it at a "porsche only" shop, but is not a dealer. Very experienced shop but they said they have not had to replace an engine on this late model. Also would like more info on this 3.6 engine mentioned.
The 3.6L engine mentioned was introduced in 2002 for the 996 model. It has appox 315-320hp in that car depending on year. Those cars had the Bosch Motronic 7.8 ECM. The 7.2 bosch ECM in your 01 S will have to be switched over to the 7.8 for the engine to run properly. You should also change over the complete exhaust to something that flows better otherwise the stock boxster exhaust will choke a 3.6L engine. For you, a realistic cost to switch over would be in the neighborhood of around 20 grand if you don't try to cut corners.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
