Old 07-26-2007, 07:37 PM   #3
trogdor
ok, times 3 or 4 on the where to put the jack stands if you're using the jack points for the floor jack!
Pelican has some pics of the hockey puck trick and I found some pics of modded jack stands that have an aluminum part on top that is the same shape as the porsche jack to fit in the 4 approved jack points but no real description of how to jack the car AND have room to place jack stands....
I did see one description of someone using a point somewhat forward of the rear jack point and apparently lifting there will lift the whole side of the car so you can get a jack stand under the front. That seems a little dangerous flopping the car around as you let the floor jack down. Plus my car didn't look like that.. maybe it was a 996??
There's really no obvious spot I can see like the frame rails on the ol' Camry, everything is flat and covered by plastic!
Anyone?? pics??
trogdor is offline   Reply With Quote
