Thread: Seat Ajustement
Old 07-17-2007, 07:09 PM   #2
easyc
The shock mechanism is operated via a metal cable that connects near the front of the seat... you could always lift the seat to see if it is disconnected... to lift the seat you need an E12 socket... four screws each corner of the rails. When removed the entire seat will lift as far as the seat belt cable will reach until you detach that. (Don't detach it tough with the in the ignition or you will have to have your airbag light reset)...
Lexington, KY Go CATS!
http://i187.photobucket.com/albums/x...s/DSCN0406.jpg
2001 986S... 3.6 swap (yep 7.2->7.8), PSS9's, GT3 seats, OEM 986 Carrera 5-spokes, and much more http://i187.photobucket.com/albums/x...me/burnout.gif
1987 928 S4 white on red and... dead
2004 Chevy Surburban... drinks gas like its cheap or something
easyc is offline   Reply With Quote
