Well the CEL came back about 300 miles later. Went to clean the MAF and after I popped open the engine compartment, I started the car and I can hear what actually sounds like a vacuum. I doubt if this is normal, because on here and renntech code P1130 is always mentioned with a vacuum leak, just didn't know it sounded like an actual vacuum! Here is pick I took, the areas circled have a bit of oil on them and it sounds like the suction sound is coming from that side. Are these the A/O seperator and oil filler tube? I guess these are common vacuum leak areas. How hard is it to fix these two?
