Old 06-19-2007, 02:51 PM   #4
Pablito
A leaky reservoir tank is just a cause of a possibly bigger problem....the tank cracks due to extensive overheating (hence the flashing light). The possible culprit is a failing radiator fan. When one of these fans start failing they shut down and water is not cooled properly...temp rises and put stress on the expansion tank.
There are several ways to check if your cooling fans are working...try starting your car in your driveway and with your engine and A/C on stand in front of your car, BOTH fans should be operating. After a few minutes they should kick in high, you will feel a gush of air from under the car...if this cycle does not repeat a few times in about 10 to 15 mins...they should be replaced. If unattended the next one to go is your water pump and afterwards the radiators themselves...the fan on the drivers side is usually the first one to go...Good luck.
1998 Boxster - trying to survive!
"I am who I am, your approval isn't required" - Jack Nicholson
Pablito is offline   Reply With Quote
