Old 06-14-2007, 11:04 AM   #5
wild1poet2
I checked my manual and it actually says to leave the donor car running. I have an '04 so maybe the protocol is different depending on the year.
Also, when I jumped my car today I attached the negative cable to the chassis for ground. Didn't work. So I adjusted the connections, still no good. I gave up and just went old school and attached directly to the negative terminal on the donor car. Started right up. LOL
Thankfully I didn't need a tow and I didn't need to jump the fuse box to open the trunk. I got it to the stealer and asked them to do a load test on the battery and check the charging system for me. Hopefully its just a bad battery. But boy it went bad in a snap. It happened to me once years ago on my harley when a 4 month old battery went bad. Like all of a sudden bad. So I guess it happens. LOL
'04 Black Boxster, 18" Carerra wheels
"If you're not living on the edge, you're taking up too much space."
wild1poet2 is offline   Reply With Quote
