Old 06-14-2007, 05:57 AM   #30
tholyoak
Yes I did it for my car. In the DME section go to vehicle data. Change the order type to a 996 cab (as I said you can try boxster but I know for sure that the 996 cab order code works (it is 996310 or 996311 for USA or ROW respectively)). Then go back and have the PST2 scan all the controllers. The cluster will now be coded for the cab top light. You can go to the instrument cluster now and the coding section and change any of the other coding options or just double check that they are configured the same as your car (ie with or without cruise, psm etc.)
Todd
Current Cars:
1989 911 Targa
1984 944 Original Owner
1971 911T
tholyoak is offline   Reply With Quote
