Thread: Nail in tire
Old 06-06-2007, 04:40 PM   #2
MNBoxster
Hi,
As mentioned the Tire is definitely compromised. It should not be run past 70MPH for safety's sake (I wouldn't run it at all personally, that's part of the Price you pay).
A Passenger car Tire is different in that Heat Management is not so much an issue - Less Grip = Less Heat Generated. The NHTSA states that the only way to properly repair a punctured Tire is with a Plug and a Patch - http://www.nhtsa.dot.gov/cars/testing/ncap/Tires/images/brochure.pdf . Yet many Tire Repair Shops will use a Plug only.
The problem for this in a Performance Tire is that you increase the Mass in a specific area (the Plug and Patch) which consequently absorbs more Heat (and releases Heat more slowly). This can lead to a Temp related Blow-out.
It's a B*tch having to replace a Tire before it's due, but that's part of the game. The cost of a new Tire pales in comparison to the costs of bent Sheet Metal, and bent People...
Happy Motoring!... Jim'99
