Thread: Seat Belt Light
Old 06-02-2007, 05:17 PM   #1
RandallNeighbour
The sensor inside it might be dirty. Take some contact cleaner (used for computer parts) and squirt it real good into the hole in the receptacle and let it dry. Then see if this helps.
Seat belt receptacles aren't terribly expensive and you can replace them easily. You may want to try this next. Just remember to disconnect the battery and wait 30 minutes after disconnecting the battery to start working or you'll get an airbag warning light as well.
