Thread: Brake Flush DIY
Old 06-01-2007, 12:13 PM   #1
CJ_Boxster
Send a message via MSN to CJ_Boxster
A good alternative to fitting your calipers with speed bleeders is to get a speedbleeder or any one-way check valve thats got good flow and place it inline with the hose you will use to direct fluid into an empty container.
When your assistant takes there foot off the pedal, the check valve will shut and you can just pump away..... remember to start from the caliper that is the farthest from your brake master cyclindar and work your way to the closest caliper to the Master.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
