Thread: lips and skirts
Old 05-31-2007, 02:34 PM   #3
porsche986spyder
Originally Posted by RandallNeighbour
The zender style skirts on the top pic are from a Houston area eBay seller and they are not good quality. Travis (forum member) has them and does not like them. I also saw them off the car and didn't like them.
However, budget skirts that look good are available. I bought and installed skirts from www.gtmotorsport.net and they're great. Just remember that the 1/2 inch tape they supply you with is not wide enough and you should buy the 3/4 or 1 inch 3M tape to get them on your car solid.
It also helps if you use screws on both ends of the skirts. I did not need any wider tape for mine. Most people don't provide the screws. I used the ones from the mud guards with some washers.
Those skirts on the red image that you have posted use FAKE side intakes. What is the point? They don't cool the rear brakes and they just look silly next to the factory vents. 2 vents next to each other on both sides. To much! Remember, "Less is More."
porsche986spyder is offline   Reply With Quote
