Old 05-31-2007, 02:09 PM   #4
Peer
Peer's Avatar
Chills wrote:
> If your cable is long enough you can route it under the passenger dash,
> then have it come out by the door, up the side, around the a-frame,
> then down into the crack between the windshield and the dash.
Okay, so today I finally got this external antenna (from China of all places) and mounted it on top of the dash at the base of the windshield, and pulled it the way Chills suggested, (thank you). But silly me, I first plugged it into the audio jack, and hence didn't get any better reception, (no mention in the manual of the GPS where to plug this thing). Anyways, now, when I finally found the right hole for it, I can see improved signal strength right away.
Thanks everyone, especially Chills.
-- peer
Peer is offline   Reply With Quote
