Old 05-24-2007, 10:14 AM   #1
ataim
Originally Posted by KevinH1990
IAre you "topping off" the tank after the pump cuts off? If you are, you might want to stop doing that and see if that helps.
It has happend about 4 times in a row. Normally I would stop fueling after the autoshut off. But the last time I got gas I only put 20 bucks in and it still had to be cranked to start. Monday I'm taking it down to the machinic to have him look at the codes again.
ataim is offline   Reply With Quote
