Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Video Center
Old 12-20-2006, 11:37 AM   #1
David J
What is the total cost and the approximate weight savings?
Jeff
jwilson95 is offline   Reply With Quote
Old 12-20-2006, 11:38 AM   #2
Send a message via AIM to blinkwatt
@ David,
That's pretty neat,I didn't know they built it from the headers back.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 12-20-2006, 02:44 PM   #3
I spent $680 before tax on the entire exhaust including labor. I'm not sure of the exact weight loss, but it's a lot. Going from the stock heavy muffler and 2nd cats to a small single muffler with the pipes has got to be a lot for a mod like this.
This past weekend Josh and I discovered a small different between his 2000 S and my 2001 S. His 2nd cats have an O2 sensor after the cat, when mine did not. Mine only has an O2 sensor before the 1st cat, and then one right after it, all on the header. Everything I did to the exhaust was after all O2 sensors.
-David
1996 993TT - current
2001 Boxster S (sold)
19" SSR GT3 - Cross coilovers - Custom Magnaflow exhaust - B&M Short Shifter - EVO intake - GT3 Seats - Hardtop
http://www.emeraldcitycustoms.com/images/box2.jpg
1986 Carrera (sold)
David_J is offline   Reply With Quote
Old 12-20-2006, 04:57 PM   #4
bmussatti
Guest
Posts: n/a
David_J, how much do they charge for a dyno-run? Thanks.
Old 12-20-2006, 05:02 PM   #5
3 runs cost $100. Another place around here charges $145 for 6 runs.
1986 Carrera (sold)
Old 12-20-2006, 05:06 PM   #6
what kind of dyno is the other and who has it?
Everything is for sale
3.6, SC 'er and other parts for sale
JP-s-in st. louis is offline   Reply With Quote
Old 12-20-2006, 05:30 PM   #7
They have both a Mustang and a DynoJet. I will PM you the info.
-David
1986 Carrera (sold)
Old 12-20-2006, 07:53 PM   #8
If the weight savings interest you, you should also maybe be interested in learning about how this has affected your weight distribution, eh? Wonder if the car handles any differently now.
2005 Seal Grey Boxster S
987 Amberectomy
eslai is offline   Reply With Quote
Old 12-20-2006, 08:32 PM   #9
I'm sure it changed it a little, but nothing that I can tell. It should be no different than when I pull the spare tire out up front for an autocross event. When I put in new seats, that will also reduce weight and change the distribution.
I guess there are many things that can change the weight distribution, but that is fine. If you calculate how much 20-30lbs changes it, it's not much.
-David
1986 Carrera (sold)
Old 12-21-2006, 09:40 AM   #10
That's pretty much what I was getting at. People like to ask about weight savings and all that stuff, but if it's not a change along the lines of 100 pounds or more, the weight savings are pretty unnoticeable.
987 Amberectomy
Old 12-21-2006, 01:38 PM   #11
The weight loss from the exhaust makes up for what I've gained this year by eating too much.
1986 Carrera (sold)
HTML code is Off
