Old 05-13-2017, 04:32 PM   #1
dulmer's Avatar
Help! Broken Roof Transmission Mounting Bolt
Old 05-14-2017, 06:00 AM   #2
dulmer's Avatar
Really wish they had used a stronger metal for these...
Old 05-14-2017, 08:49 AM   #3
Broken bolt removal tool - this may help:
https://rennlist.com/forums/996-forum/989630-exhaust-bolt-broken-in-head-don-t-panic-get-this-simple-drill-guide.html
The trick with whatever tool you use is to get a center punch mark or pilot hole dead center. Much more difficult than you might think.
http://www.brokenbolt.com/
Old 05-14-2017, 12:11 PM   #4
dulmer's Avatar
Thanks for the tip Gelbster!
Old 05-14-2017, 12:49 PM   #5
Just be careful there isn't some defect in the rest of the mechanism that is causing this problem.To snap that bolt requires a huge force - enough to damage other (expensive) parts.
There is guy on Renntech (Maurice IIRC) who is a whiz on top problems -may be worth consulting there first ?
Old 05-14-2017, 12:52 PM   #6
dulmer's Avatar
