Old 05-04-2017, 05:07 AM   #1
dulmer's Avatar
Aftermarket Keyless Entry
So I replaced the carpet in my car yesterday, and when I had the seats out, I noticed a second box beside the immobilizer. I'm assuming this is part of the aftermarket keyless entry that the PO installed? As well as the box that says "shock sensor"? I plan to remove it all as it appears to have been sloppily installed, and I'm currently experiencing lock issues on the passenger side, which may or may not be related.
Old 05-04-2017, 06:04 AM   #2
I'd do something to protect the immobilizer while you're there. The M531 is hard to come by
Woody
Old 05-04-2017, 10:07 AM   #3
dulmer's Avatar
What's the difference between the M531 and the M535? Do you recommend the ECU Doctors' waterproof case?
Old 05-04-2017, 06:03 PM   #4
oldskool73's Avatar
531 is Anti-drive-off feature, central locking system
535 is Alarm 315 MHz
(https://www.stuttcars.com/technical/option-codes/986-97-99/)
My 97 also has 531, basically it means you have central locking but no alarm system and no key remote. So I installed a similar aftermarket system to what you have there that provides both an alarm and remote central locking. The "sock sensor" (ha) detects sudden shocks and sets off the alarm if the car is bumped when it's armed.
oldskool73 is offline   Reply With Quote
Old 05-04-2017, 06:18 PM   #5
dulmer's Avatar
Thanks for the info!
Old 05-04-2017, 06:28 PM   #6
dulmer's Avatar
I'm going to get another keyless entry system. I dislike the one that was installed, and whoever did it, did a shoddy job.
