Old 01-19-2017, 03:39 AM   #1
Hood locked with disconnected battery
Hey all, so I put my car away last month before traveling for the holidays, and forgot to leave the front hood ajar. Now I need to turn the car on but can't open the front trunk because I've disconnected the negative cable on the battery. I drive a 2002 Boxster S, so the hood is released electronically.
I've searched on how to open the hood using the terminals on the left side of the driver's footwell, but couldn't find conclusive information on what I would need to buy to do so.
What parts do I need to buy to power the front hood unlocking mechanism temporarily so that I can reconnect the battery?
Thanks for your help!
TuftsAuto is offline   Reply With Quote
Old 01-19-2017, 04:50 AM   #2
2003 Base 5-speed
grc0456's Avatar
There should be a manual release cable in the passenger side wheel well. It looks like piano wire with a loop on the end. Just give it a sharp pull.
You may have to turn the wheel or even consider removing the wheel for easier access. You may first want to check if any previous owner relocated the cable to the front bumper with access behind the tow hook cover.
Old 01-19-2017, 05:39 AM   #3
Wallace River's Avatar
Here's a link to some suggestions that might help.
The name's Ian....now a former owner.....sold my 2000 Speed Yellow Base to its new owner in Nova Scotia.
Wallace River is offline   Reply With Quote
Old 01-26-2017, 08:01 PM   #4
Coaster's Avatar
http://986forum.com/forums/general-discussions/64793-removing-wheel-liner-wheel-installed.html
Here's my story.
2003 S, 6 Speed, PCM, PSM, Bose, Litronics with washers, on its' second LN IMSB, comfort top, UDP, 987 engine mount, 997 RMS, Koni Sport Shocks, H&R springs, Techno brace, comfort blinkers, nin8six windscreen, particlewave light up cubby
Coaster is offline   Reply With Quote
Old 01-26-2017, 10:12 PM   #5
Camibox
Camibox's Avatar
Here you go
Worst Case Scenario Technical Article by Pedro
Camibox is offline   Reply With Quote
Old 01-27-2017, 06:29 AM   #6
Boxtaboy's Avatar
Originally Posted by Camibox View Post
Pic of my car in that link with rear bumper off while installing my Dansk exhaust!
Old 01-27-2017, 11:56 AM   #7
I'm sure there has been enough suggestions now to get it open. I'm planning on getting one of these in the near future. With the miniaturizations of power, I thought it would come in handy one day. Would work great for the kids too on RV trips.
https://www.tryminimax.com/?mid=7493865
Can be had for about $85 if you look around.
Old 01-27-2017, 01:25 PM   #8
Way lower $ at HF with 25% coupon !But watch the HF video to make sure it does what you need.
Old 01-28-2017, 04:01 AM   #9
"50 Years of 550 Spyder"
10/10ths's Avatar
Once you are up and running....
....invest in one of these: OEM Porsche Charge-o-Mat Battery Tender Maintainer Trickle Charger 12V | eBay
Your car has several cut outs in the door gasket to allow the cable to pass through the closed door on its way to the cigarette lighter.
ALWAYS leave a parked Boxster on a trickle charger.
Always.
Old 01-28-2017, 10:10 AM   #10
Be careful with Trickle Chargers. The cheaper,older ones are inferior to the new "Maintainers" like Ctek.There is lots in Search to explain why(overcharging).
.One of these connects to the cigarette lighter socket and is what the experts use:
https://www.amazon.com/CTEK-56-864-Automatic-Battery-Charger/dp/B006G14FK8
entertainment
https://www.youtube.com/watch?v=IdZES5CQz9I
Old 01-28-2017, 11:25 AM   #11
10/10ths's Avatar
Gelbster...
...is correct. Maintainer. Sorry for the bad verbiage.
I also own a Ctek. Great product.
Old 02-11-2017, 11:28 PM   #12
Thanks all, these are some great resources. I went with option #1 and wired up a cigarette lighter jumper cable. It worked without issue, so I've now got a nice back-up solution hidden behind the passenger's seat in case of a dead battery down the road.
Old 02-12-2017, 07:31 AM   #13
On the slippery slope
JayG's Avatar
tons of those on amazon and ebay for $30
2004 996 Targa Tip
Instructor - San Diego region
