Old 12-29-2016, 05:29 AM   #1
Hp lost
Hi. My Boxster 2.5 on Dyno only have 187hp at clutch (160~ at wheels). I dont understand it because i have a 996 3.4 TB, hi flow headers and a kind of Technotorque inside plenum. Both bosch lambda new, verified TPS voltage and try a partner MAF with same results.
Anybody see anything strange in this log?
Thanks and Kind regards!!
Enviado desde mi Redmi Note 3 mediante Tapatalk
Zunamigti is offline   Reply With Quote
Old 12-29-2016, 08:35 AM   #2
Can you post the dyno horsepower and torque graph with A/F ratios? That would be helpful.
Old 12-29-2016, 08:54 AM   #3
I dont have it. I saw when tuner try to tune ecu.
Regards.
Old 12-29-2016, 10:19 AM   #4
Ben-Auto-Design
Ben006's Avatar
Dyno shouldn't be used for stright HP numbers.
Only before/after comparison ON THE SAME DYNO.
ASE certified Automotive Master Technician.
Porsche Tech in France.
www.benautodesign.fr
Ben-Auto-Design : Performance parts for 9X6 / 9X7
1982 928 S Euro
Ben006 is offline   Reply With Quote
Old 12-29-2016, 12:09 PM   #5
I know, but I have seen other Boxster and get 204hp in dynamometer ... with the improvements should have surpassed them not worsened .... do you know the maximum flow rate of air that should get? 553kg /h is correct or insufficient? Thank you!!
