Old 12-15-2016, 11:55 AM   #1
URO Parts AOS
Looking for similiar experience with an unusual AOS problem. ?
I bought the URO Parts air oil separator to replace my original one about 3 months ago. It seemed to work fine for a short while, but now it isn't. The problem is NOT the usual membrane failure however. Usually with a worn AOS there is TOO much vacuum pulled on the crankcase, and you have all the usual worn AOS symptoms.
The membrane/diaphragm is supposed to modulate the vacuum, allowing a small part of the intake vacuum to pull on the crankcase so you have negative pressure.
In my case, the new one I installed is not pulling ANY vacuum on the crankcase. Zero. It is like the diaphragm is stuck closed. I checked both ventilation hoses (from the driver side head, and from the AOS to the throttle body), both are fine. But I definitely have slight positive crankcase pressure. When I open the oil cap in the trunk I can see that. And the AOS vent valve/pressure relief over on the driver side head is popping off, getting oil all over everything. That's how I figured out that I had a problem - trying to find where the oil leak was coming from.
So, I ordered the Porsche AOS and I'll install it over the holidays. While I'm in there I will try to diagnose why the URO parts AOS failed.
One more strike against the URO parts AOS...
ksboxster is offline   Reply With Quote
Old 12-15-2016, 01:10 PM   #2
Now you know why we never use aftermarket AOS units; we have even has them fail right out of the box.
Old 12-15-2016, 01:25 PM   #3
URO = U Replace Often !!!
Avoid
Old 12-15-2016, 02:15 PM   #4
Yeah it looks like I'm just adding one more data point to the evidence on this opinion
Old 12-15-2016, 10:15 PM   #5
Originally Posted by gelbster View Post
uro = u replace often !!!
Avoid
Old 12-16-2016, 11:29 AM   #6
BYprodriver's Avatar
I have a URO Control arm I installed on my Box for about 5,000 miles, when I noticed the rear track arm was contacting the URO control arm due to it's bushing slipping out. Pelican refused to exchange it because more than a year had passed since I bought it.
Had to buy a new control arm & track arm.
Old 12-16-2016, 01:45 PM   #7
Please tell us who you bought the replacement Control Arm from.
Hopefully Pelican take note and dump URO.
Even the Vertex 'remanufactured' hack part does not separate like yours did !
Old 12-16-2016, 03:54 PM   #8
EBS in Reno NV gave me credit towards the TRW parts. EBS said the URO part had a 2 year warranty
Old 12-16-2016, 05:57 PM   #9
Bill, in the past I had very good experiences with FPC Euro with their warranty, they offer one year (no questions asked and after that they offer store credit. They offet a "lifetime warranty" on parts as long as you own your car..
