Old 11-22-2013, 03:49 PM   #1
TRPLBLK04's Avatar
Break Light Bulb
I just replaced break light bulb with a 7506 long life. Says its a 25w instead of the 21w, like called out in manual. I'm i ok with this bulb? 2004/Base.
Many thanks.
TRPLBLK04 is offline   Reply With Quote
Old 11-22-2013, 06:12 PM   #2
Yes, will be a little brighter and burn a little hotter, but as it is a brake light is not on for long and so the extra heat should not be an issue. Might be a noticeable difference in brightness between the two brake lights though, if you care about that kind of thing
gavinyuill is offline   Reply With Quote
Old 11-22-2013, 06:22 PM   #3
TRPLBLK04's Avatar
Many thanks g.
Old 11-22-2013, 06:28 PM   #4
TRPLBLK04's Avatar
@gavin.........so can you get a #7506 in a 21 watt? AutoZone called out a #7506
Thanks again.
Old 11-23-2013, 07:04 AM   #5
you sure can
http://jhmotorsports.com/shop/catalog/bulb-for-brake-light-7506-21w-sylvania-osram-b7-s4-p-596.html
21w is the norm I don't think I have seen a 25w 7506 before.
Old 11-23-2013, 07:16 AM   #6
Usercpy
ilikeching's Avatar
Has anyone tried cree led parking light, they r more powerful than oem leds, much brighter and less voltage.
http://www.flickr.com/photos/flickr_ching/
ilikeching is offline   Reply With Quote
