Old 08-25-2010, 03:02 PM   #1
Will these wheels fit?
hey guys,
found these wheels going pretty cheap on ebay,
wanted to know if these would fit my 97 986?
the specs are:
The offsets are 58 for the front and 47 for the rear
Wheels are 8.5 x18? and 10 x 18
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=330463236621&ssPageName=ADME:X:eRTM:AU:1123#ht_500wt_1154
any help would be great as the item ends soon
thanks
dsisco is offline   Reply With Quote
Old 08-25-2010, 04:13 PM   #2
Johnny Danger's Avatar
Originally Posted by dsisco
hey guys,
the specs are:
thanks
Provided the center bore for a 993 is the same as 986 (71.6), the rears will fit fine. However, +58 is a very high offset for a wheel of that size to be used on a boxster. What is the size and offset of your current front wheels ? If you can provide me with that information, I can help you calculate the difference.
Old 08-25-2010, 04:46 PM   #3
BYprodriver's Avatar
Porsche warns against running 18" tires on 1997 Boxsters because they lack the rear bracing of the later cars if that helps your decision!
Old 08-25-2010, 06:03 PM   #4
not sure what the standard offsett is for the fronts,
can anyone help on this?
Old 08-26-2010, 05:59 AM   #5
You might find some markings on the inside of the wheel that will indicate the offset. It often appears as a number followed by the symbol et.
