Old 08-01-2007, 09:15 PM   #1
DIY Seat Belt Replacement
Since no one was able to supply me with a DIY guide to install my red seat belts, I decided to make my own. I did some reading on rennlist about 996's and 987's seatbelt replacement and I then tackled the job. Here is my overly detailed DIY Guide to Seat Belt Replacement
I have only supplied the photographed dissembling of the OEM seat belts, just reverse the photo process and that will complete the project.
Time Required:
30 MIN for two belts
Tools Needed:
Torque Wrench, to replace the bolts at 36lbs
Metric Wrench Set : 8mm, 17mm
Flathead and Phillips Screwdriver
BEFORE STARTING DISCONNECT THE BATTERY!
FAILURE TO DO SO WILL RESULT IN FAULT CODES AND FAILURE LIGHTS UPON DISCONNECTING WIRES
>Step One: Remove the Cover
Remove the screw holding on the lower part of the cover
Next, Loosen the small bolt holding on the upper part of the cover
Pull the Cover Strait up to expose the Seatbelt Mechanism
**The Order Does Not matter, but I removed the Mechanism Last and I am going to reflect that here.
>Step Two: Unbolt Upper and Lower Harness Mounts
Pop open the cover and unbolt the top section of the harness.
Next, Pop off the cover and unbolt the lower section of the harness.
***CONTINUED***
http://img412.imageshack.us/img412/9591/65zxg8pcz4.jpg
2002 Boxster S
Guards Red/Black
Hacks: De-Snorkeled, Clutch Swich, Debadged, Red Seatbelts, Painted Bumperettes,
986S Badge, EVO Intake, SuperSprint Exhaust, Fabspeed Cat Bypass
My Car: http://s220.photobucket.com/albums/dd74/zackwatt/
zackwatt is offline   Reply With Quote
Old 08-01-2007, 09:16 PM   #2
>Step Three: Unbolt and Remove Seatbelt Mechanism
Slide the Orange switch outward to Unlock the wire harness. Then, gently pull off the harness
Next, Unbolt the Mechanism
After removal of the bolt the Mechanism is still held on my a 3/4 inch "rod"
To remove, pull away and outward from the roll bar. There is JUST enough room to do this.
Thats It!!!
These are the parts left over required to install new seat belts
Overall this was a really, really, easy job. I hope I have motivated some of you to replace your seat belts with some new fancy ones. Good Luck
2002 Boxster S
Guards Red/Black
Old 08-01-2007, 11:17 PM   #3
Dude, nice write up! Very thorough and easy to understand. Good point on disconnecting the battery, i bet most people wouldn't think to do that for changing out the seatbelts.
peace
Larez2
Old 08-02-2007, 01:18 AM   #4
Excellent writeup! I've been contemplating blue seatbelts for a while now. I wish I had known it was that easy, I would have probably already done it.
http://i19.photobucket.com/albums/b1...dingAvatar.jpg
Sold September 4th, 2007.
Rodger is offline   Reply With Quote
Old 08-02-2007, 06:55 AM   #5
nice writeup man, but put it in the DIY section for easy find when someone else needs this
Old 08-02-2007, 09:21 AM   #6
I've got this to do this weekend so thanks for the heads up.
What size bolts are they that I need to remove? I've only got a limited set of spanners etc and don't want to find myself taking the car apart only to find I don't have the right spanner and can't drive the car to the DIY shop to buy a new spanner as its in pieces
Cheers
davej_anderson is offline   Reply With Quote
Old 08-02-2007, 12:14 PM   #7
Sorry I don't remember, The three large bolts are all the same, just pop off the cap that covers the lower harness bolt and see if you got one that fits. Also, you can see the small bolt with taking anything apart. You can check that too. Let me know what the sizes are and I will edit my original post and put it in. Thanks
2002 Boxster S
Guards Red/Black
Old 08-04-2007, 09:28 AM   #8
Small bolt is 8mm
Larger bolts are 17mm
Old 08-04-2007, 10:47 AM   #9
HELP
Whilst changing my seat belts to some red ones I picked up all was going well until I went to remove the main bolt on the passengers belt:
I've rounded the bolt as whomever tightened this has done it ridiculously tight.
Any tips or advice?
Old 08-05-2007, 01:46 AM   #10
Peer's Avatar
> Any tips or advice?
Dremel tool.
-- peer
Peer is offline   Reply With Quote
Old 08-05-2007, 08:21 AM   #11
> Any tips or advice?
Dremel tool.
-- peer
the last resort but it may just have to be that
Old 08-05-2007, 08:22 PM   #12
I would only worry about getting the bolt off, I'm sure you can get a replacement from Porsche once it is off. Plus, I would not feel safe without it torqued down correctly. btw, try some pliers or a crescent wrench.
2002 Boxster S
Guards Red/Black
Old 08-08-2007, 03:14 AM   #13
Well I bought myself a set of these:
In essence its a normal socket that fits on the end of a ratchet with spiral teeth with a reverse thread.
I soaked the bolt with penetrating fluid and after about a minute or 2 of swearing and cursing, the bolt finally gave way. I have no idea how strong the booga was who put this on - I'm hardly a svelte chap and it took some effort to release.
Having looked at the damage I had caused to the bolt, its actually a very soft metal which I found strange.
Oh well, just need to get a new bolt now...
Old 09-01-2007, 10:34 AM   #14
where's the "after" picture?
shanec is offline   Reply With Quote
Old 09-01-2007, 10:51 AM   #15
boggtown
In reply to the hard to get unstuck comment, just get a pipe to slip over your wrench next time. Leverage makes an impossible bolt easy to release with the addition of 6 inches.
Old 10-05-2007, 12:55 PM   #16
ChrisZang's Avatar
where did you order your fancy new seatbelts? price?
Old 01-31-2008, 05:21 AM   #17
Red Seatbealts!
Hi I am new and I am trying to find red seatbealts for my 2000 Boxster, do you know where I can get it.
wcaban is offline   Reply With Quote
Old 04-14-2022, 08:02 AM   #18
Thank you this was helpful
thank you for this DIY it was helpful when I swapped out my tired black belts for new red ones to match my Guards Red.
I actually couldn't find belts for my model year 2003 Boxster but did find some for the earlier Boxster without the connection to the airbag sensor. I was able to swap the black belt in the original retractor to the red belt taken out of the replacement retractor so I still have the functions per my model year plus shiny new red belts!
It took only ~30 minutes.
eBay
2pcs Red Retractable 3 Point Fix Safety Seat Belt Vehicle Seatbelt Fit Juke
Total: $65.59
43marcus is offline   Reply With Quote
