Old 04-24-2007, 07:17 AM   #1
JAAY's Avatar
(CEL) Codes Breakdown
Sorry so long.
Check Engine Light (CEL) Codes
If your check engine light is on, go to any AutoZone or PepBoys and ask them to plug in their OBD reader and give you the codes. Then, look up the problem below and fix it. You may have to go to a dealership to have the light turned off though...
P0101 Mass Air Flow Sensor - Signal Implausible
P0102 Mass Air Flow Sensor - Below Lower Limit
P0103 Mass Air Flow Sensor - Above Upper Limit
P0112 Intake Air Temperature Sensor - Below Lower Limit
P0113 Intake Air Temperature Sensor - Above Upper Limit
P0115 Engine Temperature Sensor - Signal Implausible
P0117 Engine Temperature Sensor - Below Lower Limit
P0118 Engine Temperature Sensor - Above Upper Limit
P0122 Throttle Position Sensor - Below Lower Limit
P0123 Throttle Position Sensor - Above Upper Limit
P0130 Oxygen Sensor Ahead of Catalytic Converter (Cylinders 1 - 3) - Intercore Short Circuit or Limited
P0131 Oxygen Sensor Ahead of Catalytic Converter (Cylinders 1 - 3) - Signal Wire Short Circuit to
P0132 Oxygen Sensor Ahead of Catalytic Converter (Cylinders 1 - 3) - Short Circuit to B+
P0133 Aging of Oxygen Sensor Ahead of Catalytic Converter (Cylinders 1 - 3) - Below Lower Limit
P0134 Oxygen Sensor Ahead of Catalytic Converter (Cylinders 1 - 3) - Interruption of Signal
P0136 Oxygen Sensor After Catalytic Converter (Cylinders 1-3) - Intercore Short Circuit
P0137 Oxygen Sensor After Catalytic Converter (Cylinders 1 - 3) - Signal Wire Short Circuit to Ground or Incorrect
P0138 Oxygen Sensor After Catalytic Converter (Cylinders 1 - 3) - Short Circuit to B+
P0139 Aging of Oxygen Sensor After Catalytic Converter (Cylinders 1 - 3)
P0140 Oxygen Sensor After Catalytic Converter (cylinders 1 - 3) - Interruption of Signal
P0150 Oxygen Sensor Ahead of Catalytic Converter (Cylinders 4 - 6) - Intercore Short Circuit or Limited
P0151 Oxygen Sensor Ahead of Catalytic Converter (Cylinders 4 - 6) - Signal Wire Short Circuit to
P0152 Oxygen Sensor Ahead of Catalytic Converter (Cylinders 4 - 6) - Short Circuit to B+
P0153 Aging of Oxygen Sensor Ahead of Catalytic Converter (Cylinders 4 - 6) - Below Lower Limit P0154 Oxygen Sensor Ahead of Catalytic Converter (Cylinders 4 - 6) - Interruption of Signal
P0156 Oxygen Sensor After Catalytic Converter (Cylinders 4 - 6) - Intercore Short Circuit
P0157 Oxygen Sensor After Catalytic Converter (Cylinders 4 - 6) - Signal Wire Short Circuit to Ground or In -
P0158 Oxygen Sensor After Catalytic Converter (Cylinders 4 - 61 - Short Circuit to B+
P0159 Aging of Oxygen Sensor After Catalytic Converter (Cylinders 4 - 6)
P0160 Oxygen Sensor After Catalytic Converter (Cylinders 4 - 6) - Interruption of Signal
P0197 Oil Temperature Sensor - Short Circuit to Ground
P0198 Oil Temperature Sensor - Short Circuit to B+
P0300 Misfire Damaging to Catalytic Converter
P0301 Misfire, Cylinder 1, Damaging to Catalytic Converter
P0302 Misfire, Cylinder 2, Damaging to Catalytic Converter
P0303 Misfire, Cylinder 3, Damaging to Catalytic Converter
P0304 Misfire, Cylinder 4, Damaging to Catalytic Converter
P0305 Misfire, Cylinder 5, Damaging to Catalytic Converter
P0306 Misfire, Cylinder 6, Damaging to Catalytic Converter
P0336 Crankshaft Position Sensor - Not in Specified Range
P0341 Camshaft Position Sensor 1 - Signal Implausible, Short to Ground, Short to B+
P0410 Secondary Air Injection System - Signal Implausible (Cylinders 1 - 3)
P0420 Catalytic Converter Conversion Too Low (Cylinders 1 - 3)
P0430 Catalytic Converter Conversion Too Low (Cylinders 4 - 6)
P0440 Fuel Tank Ventilation System - Above Limit
P0441 Fuel Tank Ventilation System - Above Limit
P0442 Fuel Tank Ventilation System (Micro-leak) - Below Lower Limit
P0444 EVAP Canister Purge Valve - Open Circuit
P0445 EVAP Canister Purge Valve - Short to B+/Short to Ground
P0446 EVAP Canister Shutoff Valve (Function) - Below Lower Limit
P0447 EVAP Canister Shutoff Valve (Output Stage) - Open Circuit
P0448 EVAP Canister Shutoff Valve (Output Stage) - Short to B+/Short to Ground
P0450 Tank Pressure Sensor - Signal Implausible
P0452 Tank Pressure Sensor - Short to Ground
P0453 Tank Pressure Sensor - Short to B+
P0455 Fuel Tank Ventilation System (Major Leak) - Below Lower Limit
P0501 Vehicle Speed - Not in Specified Range
P0506 Idle Air Control - Idle Speed Too Low
P0507 Idle Air Control - Idle Speed Too High
P0600 CAN Time-out - Signal Implausible
P0603 ECM Faulty
P0604 ECM Faulty
P0605 ECM Faulty
P1102 Oxygen Sensor Heating 1 Ahead of Catalytic Converter - Above Upper Limit
P1105 Oxygen Sensor Heating 1 After Catalytic Converter - Above Upper Limit
P1107 Oxygen Sensor Heating 2 Ahead of Catalytic Converter - Above Upper
P1110 Oxygen Sensor Heating 2 After Catalytic Converter - Above Upper Limit
P1115 Oxygen Sensor Heating 1 After Catalytic Converter - Above Upper Limit
P1117 Oxygen Sensor Heating 1 After Catalytic Converter - Below Lower Limit
P1119 Oxygen Sensor Heating 2 Ahead of Catalytic Converter - Below Lower Limit
P1121 Oxygen Sensor Heating 2 After Catalytic Converter - Below Lower Limit
P1123 Oxygen Sensing Adaptation Area 1 (Cylinders 1 - 3) - Lean Threshold
P1124 Oxygen Sensing Adaptation Area 1 (Cylinders 1 - 3) - Rich Threshold
P1125 Oxygen Sensing Adaptation Area 1 (Cylinders 4 - 6) - Lean Threshold
P1126 Oxygen Sensing Adaptation Area 1 (Cylinders 4 - 6) - Rich Threshold
P1127 Oxygen Sensing Adaptation Area 2 (Cylinders 1 - 3) - Lean Threshold
P1128 Oxygen Sensing Adaptation Area 2 (Cylinders 1 - 3) - Rich Threshold
P1129 Oxygen Sensing Adaptation Area 2 (Cylinders 4 - 6) - Lean Threshold
P1130 Oxygen Sensing Adaptation Area 2 (Cylinders 4 - 6) - Rich Threshold
P1140 Load Sensing - Signal Implausible
P1157 Engine Compartment Temperature Sensor - Short Circuit to Ground
P1158 Engine Compartment Temperature Sensor - Short Circuit to B+
P1213 Fuel Injector, Cylinder 1 - Short to B+
P1214 Fuel Injector, Cylinder 2 - Short to B+
P1215 Fuel Injector, Cylinder 3 - Short to B+
P1216 Fuel Injector, Cylinder 4 - Short to B+
P1217 Fuel Injector, Cylinder 5 - Short to B+
P1218 Fuel Injector, Cylinder 6 - Short to B+
P1225 Fuel Injector, Cylinder 1 - Short to Ground
P1226 Fuel Injector, Cylinder 2 - Short to Ground
P1227 Fuel Injector, Cylinder 3 - Short to Ground
P1228 Fuel Injector, Cylinder 4 - Short to Ground
P1229 Fuel Injector, Cylinder 5 - Short to Ground
P1230 Fuel Injector, Cylinder 6 - Short to Ground
P1237 Fuel Injector, Cylinder 1 - Open Circuit
P1238 Fuel Injector, Cylinder 2 - Open Circuit
P1239 Fuel Injector, Cylinder 3 - Open Circuit
P1240 Fuel Injector, Cylinder 4 - Open Circuit
P1241 Fuel Injector, Cylinder 5 - Open Circuit
P1242 Fuel Injector, Cylinder 6 - Open Circuit
P1265 Airbag Signal - Signal Implausible
P1275 Aging of Oxygen Sensor Ahead of Catalytic Converter (Cylinders 1 - 3) - Below Lower Limit
P1276 Aging of Oxygen Sensor Ahead of Catalytic Converter (Cylinders 4 - 6) - Below Lower Limit
P1313 Misfire, Cylinder 1, Emission Relevant
P1314 Misfire, Cylinder 2, Emission Relevant
P1315 Misfire, Cylinder 3, Emission Relevant
P1316 Misfire, Cylinder 4, Emission Relevant
P1317 Misfire, Cylinder 5, Emission Relevant
P1318 Misfire, Cylinder 6, Emission Relevant
P1319 Misfire, Emission Relevant
P1324 Timing Chain out of Position, Bank 2 - Below (or Above) Lower Limit
P1340 Timing Chain out of Position, Bank 1 - Below (or Above) Lower Limit
P1384 Knock Sensor 1 - Signal Implausible
P1385 Knock Sensor 2 - Signal Implausible
P1386 Knock Control Test Pulse - Signal Implausible
P1397 Camshaft Position Sensor 2 - Signal Implausible, Short to Ground, Short to B+
P1411 Secondary Air Injection System - Signal Implausible (Cylinders 4 - 6)
P1455 A/C Compressor Control - Open Circuit
P1456 A/C Compressor Control - Above Upper Limit
P1457 A/C Compressor Control - Below Lower Limit
P1501 Fuel Pump Relay Output Stage - Short Circuit to Ground
P1502 Fuel Pump Relay Output Stage - Short Circuit to B+
P1510 Idle Air Control Valve Opening Coil - Above Upper Limit
P1512 Intake Manifold Switchover 1 (Output Stage) - Short to B+
P1513 Idle Air Control Valve Opening Coil - Below Lower Limit
P1514 Idle Air Control Valve Opening Coil - Open Circuit
P1515 Intake Manifold Switchover 1 (Output Stage) - Short to Ground
P1516 Intake Manifold Switchover 1 (Output Stage) - Open Circuit
P1524 Camshaft Adjustment, Bank 2
P1530 Camshaft Adjustment, Bank 1
P1531 Camshaft Adjustment, Bank 1
P1539 Camshaft Adjustment, Bank 2
P1541 Fuel Pump Relay Output Stage - Open Circuit
P1551 Idle Air Control Valve Closing Coil - Open Circuit
P1552 Idle Air Control Valve Closing Coil - Below Lower Limit
P1553 Idle Air Control Valve Closing Coil - Above Upper Limit
P1570 Immobilizer - Implausible Operating Range
P1571 Immobilizer - Open Circuit / No Signal
P1585 Misfire with Empty Fuel Tank
P1600 Voltage Supply - Signal Implausible (or Below Lower Limit)
P1601 Voltage Supply - Above Upper Limit
P1602 Voltage Supply - Open Circuit
P1640 ECM Faulty
P1671 Engine Compartment Purge Fan Output Stage - Open Circuit (or Short Circuit to Ground or Short Circuit to B+)
P1673 Fan Output Stage - Open Circuit (or Short Circuit to Ground or Short Circuit to B+)
P1689 ECM Faulty
P1691 Check Engine Malfunction Indication Light (MIL) - Open Circuit
P1692 Check Engine Malfunction Indicator Light (MIL) - short Circuit to Ground
P1693 Check Engine Malfunction Indicator Light (MIL) - Short Circuit to B+
P1782 Engine Engagement / Nominal Engine Torque - Short Circuit to Ground
Old 04-24-2007, 12:19 PM   #2
Dude this is awesome! Thanks! I don't have any CEL issues now. But I'm copy/paste this stuff immediately!
conradtan is offline   Reply With Quote
Old 04-24-2007, 02:25 PM   #3
JAAY's Avatar
I thought it would be helpful to us that live with that damn yellow light. 4 02 sensors for me tomorrow. $400.00
Old 04-24-2007, 02:33 PM   #4
Originally Posted by JAAY
I thought it would be helpful to us that live with that damn yellow light. 3 02 sensors for me tomorrow. $400.00
There was a thread here yesterday about someone who replaced all of his 02 sensors for around $150. I think it was in the tech forum, tho... No need to drop a ****************load of $$ when aftermarket parts are just as effective and a fraction of the cost.
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
FrayAdjacent is offline   Reply With Quote
Old 04-24-2007, 02:37 PM   #5
i keep getting 1123, no clue how to get it fixed
Old 04-24-2007, 02:42 PM   #6
I think those codes are specific to your DME,so I don't think the values are correct for every Boxster.
Old 04-24-2007, 02:44 PM   #7
JAAY's Avatar
I just got 4 $100. Bosch sensors from Napa. I dont want to go too cheap. From my expierence when you go cheap you get cheap. Well see what happens.. Right now I have 1313, 1319, 1314, 1128, 0134, and 1315. My car is not happy right now.
Old 04-25-2007, 07:11 AM   #8
fab
fab's Avatar
Jaay-
Awesome work. this is good. Copy/Paste does wonders. Don't cha think
00 Boxster Tip Blk/Blk
100% de-ambered
painted center console
painted bumperettes
autoband paint protection
wheel caps & colored crests
door sills
Valentine One
fab is offline   Reply With Quote
Old 03-14-2012, 06:56 PM   #9
Can anyone help me with instructions on how to fix error code P1600 (Manufacture Specific DTC)?
I was driving and all of the sudden my CEL, ABS, and battery light came on. I purchased a new battery right away (Interstate 700cc). Car drove fine for about 3hrs and the CEL, ABS, and battery light came back on. Weird think was a repetitive clicking noise and the car light started to dim, wipers got stuck, gauges went crazy...all UFO like...please help...thanks!
ArticBoxster is offline   Reply With Quote
Old 03-14-2012, 07:09 PM   #10
Jager's Avatar
Check your ground cable and make sure you have good connections at both ends of the cable. Do you have a multi-meter??
Jäger
300K Mile Club
Old 03-14-2012, 07:10 PM   #11
1999 base
Meir's Avatar
Sounds like you have an issue with the ignition switch.
The electric part can be easily replaced and cost around 20$.
This way or the other, a Durametric diagnostic tool will help all of you guys to better understand your issue.
Old 03-14-2012, 07:17 PM   #12
Jager's Avatar
You will need a multi-meter to check the voltage across your battery while the motor is running to see if the alternator is charging the battery. You need to see something between 13 and 14.5 volts while the motor is running.
Jäger
300K Mile Club
Old 03-15-2012, 07:09 PM   #13
I do not have a multimeter. My new battery got drained over night so I was told it has to be a bad alternator. I did checked the ground wire in the engine bay and did not see any disconnection. So should I just replace both the starter and alternator? Any one have suggestions where I can get quality parts for good price? Thanks!
Buy the way, how do I use the multi-meter and how can I test the battery if engine is not running due to the battery drainage? I can purchase one from SEARS to test out your suggestions.
Old 03-15-2012, 07:15 PM   #14
Jager's Avatar
Looks like you need to get a battery charger on that battery ASAP. I'm sure your starter is OK but suspect you have a bad alternator.
Jäger
300K Mile Club
Old 03-15-2012, 07:16 PM   #15
Ex Esso kid
When you say the battery drained overnight are you sure there are no "pulls" on the battery when the car is sitting off?
Old 03-15-2012, 09:44 PM   #16
What is a PULL? I'm guessing your saying any electronic equipment or aftermarket stuff like amps...answer to that would be I have nothing but my Alpine stereo. I had my amp and subs removed months ago. I won't be able to charge my battery until tomorrow morning. My battery charger is in a different vehicle which at a different location. Will the battery be damage due to this drain? I just bought it yesterday...I saw some Bosch Alternators and starters on Ebay...is Ebay products safe for purchasing these types of items. I did not see it on Porsche Suncoast.
Old 03-16-2012, 03:13 AM   #17
Ex Esso kid
I'm saying before you replace the alternator you need to establish that there is not something using battery energy when the car is off beyond what the manufacturer specifies. In my 944 there was a short from a security device. Charge your battery up, let it sit two days without being hooked up and confirm it holds a charge. Then hook up the battery posts and repeat the test. If the battery drains dead just from being hooked up then it has a draw on it, potentially could be from a mistake made on the alpine install.
Old 03-16-2012, 05:31 AM   #18
I think what he is trying to tell you is to put a volt-ohm meter between your positive battery cable (ignition off) and the battery terminal, you should be seeing a current draw of 40-60 mOhms; if the current draw is higher, you have a "parasitic" drain on the battery from something in the car. The source can be located by pulling one fuse at a time until the current drain stops; whatever is doing it is on that circuit............
Old 03-16-2012, 07:09 AM   #19
Ex Esso kid
JFP, exactly, I was just giving him a method to use without a meter since his earlier post said he didn't have one. Given what they cost these days everyone should have one.
Old 03-16-2012, 07:13 AM   #20
Go buy something from Harbor Freight; last time I was there, they were giving them away with a purchase........:dance:
