Old 04-20-2023, 06:23 AM   #1
Tyler
redbox986's Avatar
2003 Guards Red Boxster S "GTS" Style Build
Hi all,
I have documented this a little more on my Instagram @clutchcooker, but I will go ahead and post some photos here. The amount of things that have been done with this vehicle over the last 12 years is more than I can count, but it's ultimately become what I would call the 986 GTS that Porsche never built.
I like to drive this car as much as possible, especially with passengers, and I just like to keep it looking OEM+ (as the cool kids say).
I will likely get a different vanity plate for it this summer. (3PDL is the top choice)
Notable Modifications/Equipment:
LED Headlights/Taillights & other bulbs
LN Engineering IMS Solution (Direct Oil Feed)
7mm/20mm F/R Spacers
Eibach Pro-Kit Springs
Koni Active Struts
Akebono Composite Brake Pads
Numeric Racing Shift Cables
Uniwerks/Ben's Ball Bearing Short Shifter
987S Airbox, 997S TB/Plenum w/BMC Filter
Low Temp Thermostat
Valved Eisenmann PSE
Secondary Cat Deletes
Custom Mesh for Intakes, Radiators
Painted Bumperettes
RENNkit Bluetooth Fiber Interface
...and more
- Tyler
Current: 2003 Boxster S. Guards Red/Metropol Blue. LN IMS, Numeric, PSE, Koni Shocks, Eibach Springs, and a few other things...
Former: 2005 Mercedes C230K 6MT.
redbox986 is offline   Reply With Quote
Old 04-21-2023, 12:18 PM   #2
986tate's Avatar
Sounds Rad
986tate is offline   Reply With Quote
Old 12-11-2023, 11:28 AM   #3
The front/rear spacers. Is that for more track width for autocross or track days? Are you running special wheels with the spacers or longer wheel bolts/ wheel stud conversion?
unpolire is offline   Reply With Quote
HTML code is Off
