Old 11-11-2021, 09:28 AM   #121
Porschephile
Tomikaze's Avatar
Another epic track day at Club Motorsports
2004 Porsche Boxster S
Portland, Maine
Tomikaze is offline   Reply With Quote
Old 11-13-2021, 07:13 AM   #122
WALDMEISTER
BRAN's Avatar
Awesome...looks like you had a lot of fun on that beautiful day.
Old 12-03-2022, 01:27 PM   #123
Porschephile
Tomikaze's Avatar
Track Addict App
Made a video of my last track day with the cool app called Track Addict. Comes with free software to edit videos called RaceRender. $10 bucks!! Worked slick as hell. Also controls your GoPro so multiple videos sync up. Check out my vid...
https://youtu.be/4j3RjilrxSE
Portland, Maine
Old 12-03-2022, 01:38 PM   #124
Porschephile
Tomikaze's Avatar
Forged Wheels
Picked up a set of these during a pretty decent Black Friday sale...
Portland, Maine
Old 06-18-2023, 07:09 AM   #125
Porschephile
Tomikaze's Avatar
2023 Update
Car still on jack stands. Life gets in the way. Decided to do a mild suspension overhaul over the winter months. Good thing I'm not a flat rate technician. I'm somewhat handy but never dabbled with suspension. I just took my time, used my service manual and watched a bunch of videos on YouTube.
Picked these up back in December from a Spec Boxster guy who was upgrading...
Missing some parts so I thought I would just call up Bilstein and order the missing pieces. Think again. Only sell them as a full kit. "individual pieces would not work well together because the springs are matched to the shocks. It would be a safety issue." Bull********************.
Tarett Engineering to the rescue. Got me slightly stiffer springs (but not Spec Boxster stiff) and all the missing goodies. Picked up some used adjustable camber plates off the forum...
Looks like I was fully committed at this point. I also took the time to clean up all the cast aluminum bits with steel brush bits and steel wool. All those parts look like new now.
The rears are quite a bit more involved.
Starting to come back together...
The it was all so pretty and clean that I had to throw in new set of rotors and pads...
Next up tires and an alignment...
Portland, Maine
Old 07-12-2023, 06:46 PM   #126
How is the new suspension? I’m about to tackle the same project. Picked up a set of new PSS9’s and I’m studying 📚 the install procedure. Looks like people attack it different ways. Did you remove any of the hubs or disconnect the cv joints in the rear?
Danimal is online now   Reply With Quote
Old 03-23-2024, 06:34 AM   #127
Porschephile
Tomikaze's Avatar
Sorry I'm just seeing this. I should have gone with a new set instead of trying to piece it together with used parts. Ended up paying about the same. I did end up with slightly upgraded springs. To be honest the project was a ********************. But I'm only a YouTube certified mechanic. The right tools help. I took my time and bought the tools I didn't have as I encountered the roadblocks. Getting the struts out even with spring compressors was a pain. One of the most difficult parts. I ended up stripping the allen key hole in the top of one of the new shocks installing it. Be very careful tightening the top nut. I stripped another bolt disassembling the rear suspension. Got to know a local machine shop very well and they fixed all my f'ups. Didn't remove the hubs. Just disconnected the axles. When I got it bolted up and took it for a drive it was almost unbearable. The ride was horrible. Alignment was off. Got it aligned and corner balanced and OMG what a difference. I was contemplating going back to stock it was sooo bad. I never would have thought an alignment would affect the ride quality but thank god it did. It's stiff and need to be careful around town but I can live with it. Did a track event last October and the new sneakers and suspension made the entire ordeal worth it.
Portland, Maine
Old 03-23-2024, 01:47 PM   #128
Nice! I did the front ones myself and also stripped one of the Allen keyholes on the top. But the strut was tight enough on the mount that I don’t need to fix it until disassemble time in the future. It was such a pain in the @$$ that I had my Indy shop do the rears along with the corner balance and alignment. Definitely a night and day difference. The original struts were completely shot.
I’m always surprised how tough some of these seemly simple projects can be. I hope to get on the track one day soon!
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
HTML code is Off
