04-10-2017, 11:48 AM
#141
WALDMEISTER
Originally Posted by Gjohn3707
My happy place.
I believe it
04-11-2017, 08:16 AM
#142
WALDMEISTER
The TOP sank into a proper position, with a max of 1mm height difference. The weight of the trunk lid will take care of that
Adjustments are basically done, now it needs sanding touch ups.
While adjusting the side locks, I locked them in first, let the roof loosely sit on in, and slowly tightening the screws and let the TOP&locks "adept" to each others form.
After doing that, the TOP slowly sank into the proper position with proper gaps. I made sure, that all the time the front gap was at a max of 5-6mm (semi locked center lock helps).
It is basically ready to see the paint shop. They will still have a lot to do with sanding/primer/filling the cut out holes... to get it to a "factory" finish, especially with GFK. Side windows, rubber seals etc. will be done by them as well, as they are the Pros, not me.
Foto shows the "unlocked" side locks. That's why the TOP is sitting higher.
04-11-2017, 09:18 AM
#143
Thought I'd join in from the Emerald Isle.
Seal grey, dark navy leather and dark navy top.
Sent from my iPhone using Tapatalk Pro
Traco
_________________
Older but no wiser.
2003 Boxster S, Seal Grey
04-12-2017, 10:39 AM
#144
WALDMEISTER
oh...rare combo, very nice
welcome & sláinte
04-13-2017, 09:56 AM
#145
WALDMEISTER
...the gaps are absolutely okay for my taste, will see how the trunk lid works out later
04-14-2017, 07:29 AM
#146
WALDMEISTER
Alright...so there still is detail work to do, before bringing it to the paint shop!
I noticed, that the side windows lift the roof when fully closed, just 1mm but noticeable, on both sides without the rubber seal. Sanding might do the trick.
I loosely put the trunk lid into place to see if the weight pushes the TOP a little more down.
Left side yes...with sanding and adjustments i might get a properly leveled gap.
Right side NOPE. It still sits 2mm too high, so the gap is not properly leveled. Anyone ran into the same problem while installing the Z-Top? Hints are welcome
If I can't fix it, I gonna let the paint/body shop guys try their luck
It starts to shape up
04-24-2017, 11:48 AM
#147
WALDMEISTER
Originally Posted by BRAN
...If I can't fix it, I gonna let the paint/body shop guys try their luck
LOL...the paint shop guys keep any kind of "body work" besides the paint job on a long arm away from them. They are not even "touching" the rubber sealing. I guess they really don't like to work with fiberglass. Even the paint job sounds like a very special and long procedure
05-03-2017, 09:04 AM
#148
WALDMEISTER
LOL...they are not impressed by the used primer, as it chips off too easily and will cause more problems than joy later on, so I decided to get it properly re-done by them.
I hope to have it ready before winter
05-18-2017, 08:05 AM
#149
WALDMEISTER
an outlaw barn find?
05-18-2017, 08:22 AM
#150
WALDMEISTER
05-18-2017, 10:12 AM
#151
The top looks great Bran!
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
05-19-2017, 07:19 AM
#152
WALDMEISTER
Thanks, Bruce!
Well, as picky as the paint-shop guys were with the cheap Chinese primer, they delivered an excellent result. Too bad, that they did not want do the rubber sealings.
Next to-dos:
- glue the sealings (front, sides, back). Any tips&tricks, what glue to use are welcome!
- wirings (i got oem parts/connectors, which are not included in the z-top package, only electrical stuff was a 5$ brake light  ) I'll post later, which part numbers to get
If I would be the manufacturer, I would only offer a complete package including OEM stuff...saves you time, money & nerves...and it is only a few $ more. Sometimes I don't understand people's business models.
- trunk lid adjustments & installation, probably the most difficult part, will see...
05-28-2017, 05:10 AM
#153
Out and about this morning
Traco
_________________
Older but no wiser.
06-05-2017, 12:25 PM
#154
WALDMEISTER
Thanks, Bruce!
Next to-dos:
Seems that installing the rubber sealings is not an easy walk in the park.
Top is lifted by the side windows (when closed) with sealings attached...~3mm.
--> solution: Torx screws to adjust height and angle, accessed through two holes at the bottom of the door. I won't touch the angle, but height only. Something, which is nowhere mentioned in the installation manual
The Bentley manual describes it nicely!
Lower part of the side windows barely touch the sealings (--> gap), probably need to build up 5mm on the side arches.
--> will see how that goes
Finding a proper glue was not a simple task
--> I got TEROSON 444651 Kontaktkleber
So...I am still fighting with the TOP
Why easy, when you can have it the hard way...
06-10-2017, 09:25 PM
#155
Someone was suggesting that Seal Grey looks great in low light and there should be more night pics in here.
2001 Boxster S, TipTronic in Seal Grey aka "The Imp"
2001 TE50, ESS in (now) Grigio Titanio Matallizzato aka "The Golden child"
06-15-2017, 08:06 AM
#156
WALDMEISTER
not sure, if i want to start another project (short shifter) before this arrives...
07-02-2017, 04:58 AM
#157
WALDMEISTER
Just installed...on a rainy sunday
took my sticky old rubber one to a saddler...finest OEM leather quality, just like the OEM crested arm rest. What a difference...
07-02-2017, 05:58 AM
#158
Genius
07-19-2017, 07:39 AM
#159
WALDMEISTER
...and another project done:
Blindspot detection sensors + interior LEDs integration
The outline of the milky plastic-glas is defined by the interior cover piece setup, which holds it in place.
Nice amber led light, noticeable, but not "in your eye".
07-28-2017, 10:30 AM
#160
WALDMEISTER
Hatch attached, but has to be adjusted carefully...what a PITA
Tip for others: Hinges should be installed as low as possible...and should be in the most backward pointing position possible.
BUT the U-Profile to lock the hatch should be in the most inwards/forward pointing position possible.
My hatch needs to move a good cm backwards to close and lock.
| Thread Tools |
| Display Modes |
Linear Mode
HTML code is Off
