Old 05-26-2012, 04:01 PM   #1
1999 boxster 986 leaking under TQ
Has anyone any pics of removal and seal for Converter.
does anyone know how much oil converter holds,I know trans altogether hold roughly 9 quarts.replaced pan filter filled per instruc. but only took about 7 and there"s oil pouring straight down out of bottom front.could the over flow dump threw like that oor is Converter seal prob. shot?oil did not smell burnt and was loow because trANS STARTED ACTING UP >KIKING LIKE THEY DO WHEN LEVEL GETS @ QUARTS DOWN OR SO. rite before change oil it did blow just any tran fluid that was in it out and barely made it home at the time.Bought it used had small leak at time but thought it mite just be pan. I'am thinking conv.seal shot.
any info besides throw a match on it would be great. Thanks you'all
ncerino1 is offline   Reply With Quote
HTML code is Off
