Old 10-15-2009, 04:29 PM   #1
When you push the shifter side to side it rotates inside white nylon plastic bushings and plastic inserts; one in front and behind the lever. My guess is you have binding in there preventing the shifter centering. You can't pull it apart easily without breaking the bushings, so it might be a good time to upgrade to an aftermarket unit or maybe a 987 5 speed shifter.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 10-15-2009, 08:04 PM   #2
Have you by chance put any coins in your ash tray? The can get into the shifter mechanism during spirited driving.
You can always pop off the leather trim around the base and have a look to see what's going on, spare change or not.
HTML code is Off
