Old 08-02-2008, 02:13 PM   #1
How To Piant Your Side Vents
Hi, I am thinking about removing the side vents from my 2001 S and painting them from the stock black to colour coded silver, has anyone out there tried this? If so any hints and tips? :dance:
ALL THAT YOU FASHION, ALL THAT YOU MAKE, ALL THAT YOU BUILD AND ALL THAT YOU BREAK
Y2BOX is offline   Reply With Quote
Old 08-02-2008, 04:19 PM   #2
IMO I don't like it when people spray the entire bottom part of the vents:
Just a picture to show you what it may look like. I haven't done it, but I assume all you really need to do is remove the vents, clean them, and tape over the parts you don't want painted...
"If you feel like you're under control, you're just not going fast enough."
-Mario Andretti (cliche!)
2002 Boxster S 6 Speed (Ocean Blue/Savannah)
-De-Snorkled, Porsche (B&M) Short Shifter, EVO Shift Linkage
-H7 HID Upgrade
-Rennwerke Maintained
1998 Bouvier (Brindle)
http://inlinethumb03.webshots.com/42...425x425Q85.jpg
fragdude is offline   Reply With Quote
Old 08-02-2008, 04:38 PM   #3
It would seem very simple. Just unscrew the vent, remove it carefully, tape, sand and prep it (using denatured alcohol?) and then primer followed by light base coats and eventually clear. I like Paintscratch.com's paint. I may do this next week.
Maybe someone with more experience can chime in here.
http://img360.imageshack.us/img360/3864/artbox2lf7.jpg
18x10/18x8.5 wheels on Dunlops, Eibach springs, De-snorkled, Debadged, Painted Bumperettes, Arctic Silver Interior trim & Deambering (in process)
RobZ is offline   Reply With Quote
Old 08-03-2008, 12:30 AM   #4
Smile
Thanks Robz, I will attempt this next week, I will probably do the fronts aswell.
HTML code is Off
