Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Interesting Links > Porsche Info Links
Old 07-21-2011, 01:59 AM   #1
Audio Amplifier Location
Can anyone please tell the location of the Audio Amplifier all I am trying to do is fit a hands free kit (Parott 92000)
1098chris is offline   Reply With Quote
Old 07-21-2011, 06:18 AM   #2
assuming you have an amplifier (early Boxsters w/o a premium sound pkg did not and therefore only had dash speakers)... it is mounted in front trunk against firewall. If a 986, it's up high behind spare tire. If 987, it's low behind panel that hold wheel lock key, tools and tire goop).
Good luck
Old 07-21-2011, 10:57 AM   #3
Front boot.
Old 09-29-2012, 04:48 AM   #4
Send a message via Skype™ to Gregtenerife
Hi Chris,
did you manage to fit the 9200 in the end? I am thinking of connecting into the cables going into the yellow plug at the back of the head unit but I am concerned about connecting an amplified source to the amp inputs. What did you do?
Gregtenerife is offline   Reply With Quote
Old 09-04-2013, 02:10 PM   #5
mine is also in the front boot near the multi cd changer
Mikelove is offline   Reply With Quote
HTML code is Off
