Old 03-05-2007, 10:37 PM   #1
aglsteven's Avatar
Annoying squeak in driver's seat
Hi guys,
My driver's seat has developed a really annoying squeak, everytime I push the clutch in, or when the car brakes. It seems to point to the seat not sitting square anymore, and it squeaks when it gets an off-centre push.
Is there an easy home fix, or is it a case or parting with some high denomination notes at the garage?
Cheers
Alex
aglsteven is offline   Reply With Quote
Old 03-09-2007, 07:31 AM   #2
Originally Posted by aglsteven
Hi guys,
Cheers
Alex
I've also got an annoying squeak from the driver's seat (upright portion_ everytime some pressure is applied i.e. at the same time as you indicated, pressing the clutch etc.
I assume the squeak is from a component in the seat that has either come loose or is broken but I don't want to take the seat apart.
Anyone got any faults?
davej_anderson is offline   Reply With Quote
Old 03-09-2007, 10:40 AM   #3
Mine squeaks come from it being slightly tilted to the right side and since I have long legs I have the seat all the way back and it rubs against the padding on the roll bar. Somebody suggested to place a couple of thin washers where it bolts to the base (right side) but I haven't done it yet.
spgribben007 is offline   Reply With Quote
Old 03-19-2007, 05:34 PM   #4
aglsteven's Avatar
Tool Pants help please
Hi Tool Pants,
You're the guru. Can you advise if it is easy to lift the driver seat to insert a few washers? I too am over 6' and I think my seat is slightly lop sided, which may be aggrevating the squeak.
many thanks
Old 03-25-2007, 07:48 AM   #5
Porsche "Purist"
Paul's Avatar
I can't resist asking:
Does it occur only when your wife is driving?
1987 924S. 2002 996TT. PST-2
Old 03-25-2007, 09:14 PM   #6
aglsteven's Avatar
very good.
That's like asking if a tree falls over in the forest when no one is around, does it make a sound?
