Old 03-28-2007, 04:42 PM   #9
Couper1's Avatar
Originally Posted by MNBoxster
Hi,
Yes and if your radiators are clogged, the Fans will make more noise as they try to suck the same amount of air through smaller openings(because of the restrictions).
Also, you are working the Fans harder and Hotter and so their bearings will wear out prematurely leading to Fan replacement...
Happy Motoring!... Jim'99
Thanks Jim, and everyone else too. I will go in and clean out the front radiators. I'll post the results afterward. Great info!! Thanks
Couper1 is offline   Reply With Quote
