03-02-2007, 09:41 AM
#1
There are 996's with 3.4's and a 5 speed tiptronic. So I don't think that a 6th gear is required.
03-02-2007, 09:45 AM
#2
If that is true, then you got me. Sounds like it's posible with your car to do then. I would definately upgrade the clutch, CPU and brakes then. Good luck if you decide to do this mod.
03-02-2007, 10:10 AM
#3
Guest
Tiptronic doesnt have a clutch though... Brakes are fine, suspension Id recommend upgrading, not because of the conversion, but because if its time for a conversion, its time for new springs and shocks. If you take the cpu from the car you got the engine from you shouldnt need reprogramming, youd be in line for a 3.6 conversion. Us 97-99 boxs can do the 3.4 no sweat without a bunch of jerry rigging.
03-02-2007, 10:39 AM
#4
I think you need to upgrade transmissions to handle all the new power. That's what I've heard anyhow.
Miss my Boxster
03-02-2007, 12:27 PM
#5
I have had a 3.4L conversion done in my 99MY and while 3.6 and 3.8 conversions can be done, imo, unless its a track car, the additional hp as well as the additional cost involved probably isnt worth it.
Some clarifying points:
- Part of the reason a 3.4L (e.g. '99 996) conversion is easier (and less expensive) other than the price of the engine is because the 97-99MY is non-eGas so no rigging is involved to make it work. 3.6/3.8 engine are eGas and have to be rigged which adds to cost.
- The old transmission can be used on 3.4 - 3.8 conversions, if it's a manual then a stronger sport clutch is used to handle the additional power and i was told a tip should handle it fine as well.
- Some parts were used as donor parts off of my 2.5, such as fuel rails (boxster and 996 are opposite of each other), old flywheel (996 flywheel was about 5-10mm thicker and would scrub the bellhousing if used), a few other small pieces i do not recall.
- My old ECU was used although it had to be sent out to be reprogrammed for the proper mapping of the 3.4, otherwise you end-up with a 3.4 that has approximately the same power as the old engine yet backfires like crazy under hard acceleration from incorrect oxygen/fuel mix. I am not sure whether the old ECU can be used regarding a 3.6/3.8 swap.
- New headers/cats are definitely required for the engine although you can get away with using your old muffler (that is what i am doing presently)
- Stock brakes are fine for daily street use. I'd consider upgrading if it were a dedicated track car.
- Downshifting in some instances becomes an option as opposed to a have-to...
hope this helps some.
- ian
03-02-2007, 12:41 PM
#6
Thanks! This is the type of info I was looking for. Who did your conversion?
03-02-2007, 01:39 PM
#7
- ian
