Old 02-23-2007, 05:32 PM   #1
2004 Boxster S Dead Battery Advice?
I have a 2004 Boxster S that I may drive once a week fairly short distances. The last few times I drove the car I noticed the battery sounded a bit week. I drove the car about 50 miles today and I went to start the car and there was not enough juice to turn it over. The existing battery looks original and the low battery light did not come on. I have the hood open.
Would you recommend replacing the battery or trying to charge it?
Thanks.
Breezer is offline   Reply With Quote
Old 02-23-2007, 07:12 PM   #2
You can try to charge it; it certainly won't hurt, but after a 50 mile trip, getting the results you did?
I think it's time for a new one- it was in my case.
wanna986 is offline   Reply With Quote
Old 02-23-2007, 07:47 PM   #3
The battery is pretty new and should be good if it was properly maintained. I would try charging it and see if the problem reaccurs. It could be a bad alternator but more than likely it's the battery if the problem persists.
Old 02-23-2007, 07:57 PM   #4
The 04 I just bought already has a replacement battery. It only has 7400 miles, so I'm sure it sat alot. I read some old posts, and someone last year ran into the same problem. The warranty didn't cover it, $280 for a factory replacement, or about a $100 for an interstate MTP-91. Have the battery and alternator tested to see what the culprit is.
90red is offline   Reply With Quote
Old 02-24-2007, 06:27 AM   #5
Brucelee's Avatar
Smile
The battery COULD very easily by shot. The OEM batteries from Porsche are JUNK and the Boxster draws quite a bit when just sitting. These batteries do not do well without a lot of driving.
You can buy a fine battery at Coscto for $52. plus tax and install yourself, it is easy.
Since a charge is likely free (if you have a charger, highly recommended) give it 24 hour charge and see what happends.
Odds are it is a goner.
Bosch batteries are the pits.
Rich Belloff
Old 02-24-2007, 10:53 AM   #6
Costco was still closed when I went by so I ended up at AutoZone. The battery came back as bad on their tester. In turn, bought a Duralast for $69. It appears to be charging fine now and good to go. Thanks for the assitance.
By the way, this 2004S is for sale in So Cal. I will post a link to autotrader in the classified section. Thanks again.
Old 02-26-2007, 10:28 AM   #7
Yes, I would agree with the stock battery being bad. I barely have 1500 miles on my 07 987 and I let it sit for about 5 or 6 days and the battery was completely gone. This is in So. Cal. too so it is not like it gets super cold here.
aren040 is offline   Reply With Quote
Old 02-26-2007, 11:35 PM   #8
I can vouch for that, the stock batteries aren't very good and still overpriced, I did get 6 years out of it, in a lot of cases it was always only just turning the car over.
Just replaced it, the new battery seems to be holding up, though the boxster draws a lot of juice for some reason..
911-996 is offline   Reply With Quote
Old 02-27-2007, 07:19 PM   #9
I would assume that opening / closing the top without the car running would put a huge strain on the battery.
Just a guess...
Nick
1999 986 ( Black )
1998 MB C280 ( Black )
1999 BMW K1200RS ( Yellow )
2005 Audi A4 ( Red )
Old 02-27-2007, 07:45 PM   #10
Brucelee's Avatar
Smile
Not really a top issue, as the 911 coupes are deadly on the batteries also.
It seems to be a combo of electrical draw issues when the Box is sitting.
Plus, the OEM battery is junk.
Rich Belloff
Old 02-27-2007, 07:54 PM   #11
I dont understand
I dont understand this "cant get the hood open if the battery is dead?
I have a 2000S and it seems like it is a cable operated latch...
And even if that isnt true, I just pulled out my right headlight to change a bulb and saw there was a pull cable behind the front bumper, so if i reached my hand through the vent and up I could grab the cable, pull and the hood would open..
Dont you all have that? I didnt put it there and it looks like a factory item.
Dohertycm is offline   Reply With Quote
