02-21-2007, 07:34 PM
#1
Finally: Dyno charts of de-snorked 986S!!!
Greetings all,
I recently purchased my 2001 Boxster S (last week Wednesday), and could not wait to start playing around with it on my dynamometer. I am an engineer, tuner and enthusiast, and have designed parts for NSXs, S2000s, and even factory supported FWD drag race teams. My race program involved many secured world records...but I digress.
Since I own my own Dynapack Chassis dynamometer, and noticed some confusion in this board (yes, I have lurked for a while) in regard to if de-snorking produces any other benefit above an enhance intake roar, I took it upon my self to perform the following test. Each run was repeated to ensure credibility.
My bone stock S: red line
De-snorked (15 minuets later): violet line
A 5 WHP GAIN!!!! In addition, almost 3 ft/lbs of torque
Finally some proof, and feel free to share this with our peer members. This is the most cost effective gain I have seen in a while!
On the dyno:
Left over "organ":
No tyre interface to introduce, variables like other cheaper intertia dynos. More data to come, as I try some interesting technology on the S...
02-21-2007, 07:58 PM
#2
Guest
You lucky son of a gun, how much did that dyno cost you? I presume thousands...
Im glad you did the dyno's, all you need to do now is test some other stuff like a cold air intake, or exhaust.
02-21-2007, 08:08 PM
#3
The unit set me back $61K, but worth every penny: more accurate and safer than inertial roller dynos. Since K&N is helping my race program this year, I will have to get a filter for the Boxster and test that too.
I design my own headers and exhaust systems for my race cars and many inline 4 vehicles, and will soon embark on making some for my S. When I spent some time studying the undercarriage earlier today, I noticed that the factory exhaust system is in dire need of some improved breathing! More ponies to come!!
Bisimoto Engineering
2001 modified Boxster S, slate grey, red interior
02-21-2007, 08:16 PM
#4
Guest
Thats a lot of money. But if you design your own exhaust systems and headers, Id suggest making short equal length headers and gradually make your way to the longer "racing" style headers. That way we can see if there is a linear form to flow vs backpressure needs and where the optimal points are.
02-21-2007, 08:30 PM
#5
You are amazing, Jonathan. There is so much power in header tuning, it is mind boggling. I have data on your suggestion, and found out that high performance engines hate back pressure, but require fuel and ignition optimization for improved efficiency and power: the main reasons my simply reducing BP sometime results in power loss. I look forward doing some primary length tests on each bank using a true "burns-style" merge collector.
02-21-2007, 08:38 PM
#6
Porscheectomy
There's also the scavaging effects of the right length of pipe.
It'll be fun to see what you learn while playing with the car and the dyno.
02-22-2007, 08:05 AM
#7
This would have been good to know before I installed my TrueFlow. I could have done them together at the same time. Is there a how-to section in here showing how to do it yourself. The one this last guy posted doesn't even actually de-snorkle, it just shows how to remove the retaining ring around the snorkle and then they put it back together with a mesh overlay.
02-27-2007, 12:11 PM
#8
Cool
Thanks for the great info. For most of us, it's not worth the cost of the dyno run. But it's good to know.
Did you alternate snork, no snork, snork, no snork, etc.? The reason I ask is that the DME does some weird ignition advancement/retardation compensation when it senses a change in air flow. I know that if I unplug my MAF, I get a noticeable increase in power.
Would you be willing to try the same thing with the stock air filter versus K&N?
02-27-2007, 02:34 PM
#9
Huh...
That's interesting. I was wondering about that.
Will remove mine tomorrow, btw
Miss my Boxster
02-28-2007, 07:43 AM
#10
Yes. My race team is sponsored by K&N. In the next couple of weeks, I will order a K&N filter from the factory for the S and post results as well.
Ed, I am willing and able to test the exhaust systems. I have also ordered a Porsche System Tester 2 to assist with my diagnosis during testing. Thanks for the kind words, and I will keep all informed of my data aquisition.
02-28-2007, 07:56 AM
#11
Holy crap! You've got some deep pockets there, friend! Aren't those suckers something like $3-4k or more?
02-28-2007, 08:09 AM
#12
Forgive me for not being clear: I ordered a PST from Durametric for $630. I wish I had DEEP pockets..lol.
02-28-2007, 08:51 AM
#13
For what it is worth, here is info on the 987/Cayman.
http://www.pca.org/tech/tech_qa_question.asp?id={24041683-6376-4DD9-80EC-3A5F748391BF}
If the link does not work I think you have to copy and paste.
03-13-2007, 12:17 PM
#14
Can't wait to see the results.
When are you planning to do this?
05-18-2007, 05:13 PM
#15
I desnorkeled my Boxster S yesterday. I had the same issue with it not wanting to come out. I pulled really hard several times and it wouldn't budge. I was afraid of breaking something. Then I tried twisting and pulling. You can't twist much due to the very tight space but it finally came out.
I really hope this is worth it because it will no doubt be a pain in the ass to put it back in.
02-27-2007, 03:13 PM
#16
Congratultions on your new Boxster project car!
Thank you for posting your dyno info. I will look forward to your continued HARD work on your Boxster.
I have put up a suggestion that Deluboz send you a set of headers to dyno.
We all have been searching for reliable test data on ALL matter of engine modifications --- as you can see by the reponses to your post
You have sparked great interest with your Dyno results -- I will continue to watch for all your future hard work results and appreciate your efforts to document the work (especially the photos).
Take care,
Ed
02-28-2007, 07:02 AM
#17
When you unplug the MAF you will get a CEL. You can easily reset it by disconnecting the battery for a short time (first make sure you have your radio code if your car is pre-2003) or by using a OBD-II reader.
When you unplug the MAF the car freaks out briefly. Then it uses an approximation (based on throttle body temperature readings, I believe) to decide how much air is coming in. The car has a tendency to stall when warmed up and idling. But in my base 1999 Boxster, I could keep up with 2000-2002 BoxsterS cars in flat out acceleration up to very high speeds.
04-06-2012, 08:46 AM
#18
Carnut
BUMP! Intereresting read....
'14 Boxster
04-06-2012, 07:29 PM
#19
Semi-snorkled
I desnorkled my car, but did not like the looks of the resulting profile from an air flow standpoint. If you have studied fluid mechanics, it is well known that the pressure drop from an inlet nozzle is much less if the nozzle projects into the stationary air flow.
So, I cut my snorkle off a few inches out and re-attached it:
Kippis
986S
991S
Van Diemen RF97
04-06-2012, 08:10 PM
#20
Porscheectomy
I have my graduate degree in fluid mechanics and have worked in airflow management for twelve years up to and including today. I have no idea what you're talking about with respect to this geometry.
