Old 01-07-2007, 07:31 AM   #1
911 Wheels on my Boxster
I am looking at buying some factory rims off a gentleman with a newer 911 C2.
The rims are this style:
http://cgi.ebay.com/ebaymotors/Porsche-Carrera-wheels-rims-18-911-928-944-Boxster_W0QQitemZ320067742526QQihZ011QQcategoryZ43 958QQrdZ1QQcmdZViewItem
Will these fit my '99 Boxster without any spacers?
Thanks in advance
mookarma is offline   Reply With Quote
Old 01-07-2007, 08:21 AM   #2
Allen K. Littlefield's Avatar
read furthur
Yo, if you read furthur down you will note in red script that these wheels "Fit all Boxsters without spacers", so I imagine you will be ok. I am thinking about these myself but wish they would make them in 17".
986geezer
Old 01-07-2007, 08:22 AM   #3
His auction says it will fit boxsters. Hmmm...
Miss my Boxster
Bavarian Motorist is offline   Reply With Quote
Old 01-07-2007, 08:24 AM   #4
re.
Also I think that the factory rims you are considering are not as wide in the rear as these Italian aftermarkets. Again, I believe you should be ok and the factory rims I think are even lighter in weight. If you get a good deal go for it and send us some pics when you have them mounted on the car.
986geezer
Old 01-07-2007, 08:39 AM   #5
Thanks, just to clarify the rims pictured are the style of the rims I am getting, but I am getting the Porsche factory rims from a C2 911. I have seen the rim on some Boxsters, but I've never known if there was a Boxster rim and a 996 rim, or if it was the same part.
The deal should be pretty good, depending on how much tread is left on the tires. . . anybody know the life expectance of bridgestone potenzas? lol
Old 01-08-2007, 08:25 AM   #6
The ebay Wheel Enhancement wheels have the :
"Sized (2)18x8et 50mm and (2)18x10et 47mm"
You are looking at 911C2 factory wheels, which
may be different offset OR may be the correct offset.
...need to check with your seller about the offset and
look in your Boxster manual for the correct offset for
18" wheel sizes.
Good luck,
Ed
PS: most all can be made to fit with spacers
Sboxin is offline   Reply With Quote
