Old 06-04-2026, 11:09 AM   #21
redpepperracing's Avatar
Originally Posted by BrakeExpert View Post
When you say an engine is "sideways" what does this mean? I'm not familiar with this terminolgy?
He wants to do a Seafoam soak of the pistons to try and see if he can potentially unstick piston rings, but the engine is a flat six, so anything you put in the combustion chamber is just going to pool on one 'edge' of the piston, not the top, since the piston is vertical.
redpepperracing is online now   Reply With Quote
Old 06-04-2026, 03:27 PM   #22
Originally Posted by redpepperracing View Post
9 is tachometer.
Sorry, I was trying to be funny. Usually with a V-Type engine or a straight configuration, when you get stuck oil rings that cause burning, you can pour some decarbonizing agent (sea foam, trans fluid, etc) and dissolve the build up causing the rings to stick. you cannot do that with a flat (or side to side that I called "sideways") because only a very small portion of the ring will sit in the mixture whereas you will get 100% coverage with an up and down piston. I'll stick to auto repairs and leave the comedy to the pros.
Dllrd23 is offline   Reply With Quote
Old 06-04-2026, 03:33 PM   #23
thanks. I'm going to compare the diagrams between the 2 tonight. Looks like the first 3 are comparable. I wonder if pin 9 on mine is a 12V pull down circuit and yours in the 03 is a pull up. I check into it and let you know.
Old 06-05-2026, 05:24 AM   #24
Mine is a 2000. I checked the wiring diagrams for both and they look the same, I can't see why they would make them different.
Old 06-07-2026, 07:48 AM   #25
I don't know why I did it but I looked yours up as an 03. My mistake. Going to the shop tomorrow and Im going to check out a hunch. I could've sworn that the live data could be read when I first started the Box. The only thing that I have done since is install the 4 o2 sensors. Wondering if maybe one is worried incorrectly and pulling the k-line down when started. I'm going to unplug all 4 and check.
