Old 01-07-2025, 03:12 AM   #1
DIY is the only way!
GatorDun!'s Avatar
Digital Speedometer display problem
I have what looks like a scratch on my display. I'm not sure how else to describe it. It's always there regardless of the speed display.
Has anyone else seen something like this? I'm not sure if there's a fix short of replacing this part of the cluster (if that's even possible).
Learning through the experience of others.
2000 Boxster S, 6spd, ~92k miles
GatorDun! is offline   Reply With Quote
Old 01-07-2025, 10:38 PM   #2
Seems a common thing. There are replacement screens out there (don't know whether all specific versions are) which you can solder into the current cluster.
For example:
https://partworks.de/gearworks/en/search?sSearch=986
I'm sure there are US sources as well.
Marc_986 is offline   Reply With Quote
Old 01-08-2025, 04:32 AM   #3
Moderator
Mine did that one winter. Cleared up once the weather warmed up. I learned here on the forum that it might clear up in warmer weather.
Bill Ladd is online now   Reply With Quote
Old 01-09-2025, 02:18 AM   #4
GatorDun!'s Avatar
Thanks for the link Marc. That might be worth trying.
Bill, down here in Florida, it's usually warm so I'm not sure that's the issue. It'd be great if it was though!
Old 01-11-2025, 06:09 AM   #5
The next sunny day with temps in the 60's or higher park the car outside . Put the top down and park the car so the sun is hitting the dash . You want the sun to be lined up to hit the gauge faces .
After a few hours fire up the car . If the LCD " spot " hasn't disappeared then you are past the point of it self healing . Replacement of the screen is the next option or just live with it .
rfuerst911sc is offline   Reply With Quote
Old 01-11-2025, 05:39 PM   #6
GatorDun!'s Avatar
It's worth a try!
Old 03-19-2025, 09:15 AM   #7
GatorDun!'s Avatar
Yep. You were right. It's almost completely gone. Just one little spot left.
Old 03-19-2025, 01:42 PM   #8
Moderator
Good deal! Mine got pretty bad one winter a few years back. Soon as it warmed up outside it went away. Hasn’t reappeared since.
Old 03-20-2025, 08:45 AM   #9
I would do the sun routine a few more times to see if it completely heals . I have read plenty of cases where this fixed the issue . But I have never seen any comments regarding the longevity of the repair.
Old 03-20-2025, 05:57 PM   #10
GatorDun!'s Avatar
I plan on it!
