Old 01-23-2024, 11:18 AM   #1
987 ABS pulses/rev
Does anyone know how many pulses per revolution the ABS ring in the bearing of the 987 has? I searched the internet, fora and bearing manufacturer datasheets, but haven't been able to find the answer yet.
Reason for the question is that I will be running 987 driveshafts in my 986. The only obstacle seems to be the ABS because the 986 has an inductive sensor and a reluctor ring whereas the 987 has a hall sensor with the magnets integrated in the bearing.
Worst case I'd need to find some 986 S shafts and get the wheel side joint attached to the 987 shaft.
Marc_986 is offline   Reply With Quote
Old 01-27-2024, 10:41 PM   #2
I’m sorry but I do not know the answer to your question. However just wondering why you are fitting 987 driveshafts to a 986? Is there some technical advantage?
Nitro V8 is offline   Reply With Quote
Old 02-04-2024, 11:01 AM   #3
The advantage is two fold in my case;
1) The shafts fit the Porsche G87/21 and therefore the Audi 0A2 gearboxes. I'll probably mount the G87/21 now as long as I have the 2.5 Boxer and will move the Audi version in once the V8 goes in.
2) I expect them to be strong enough to hold the torque of the V8 which I want to drop in over the next winter.
